quadzilla help please...
I have recently purchased a quadzilla commander and a 4 bank chip. I bought them seperate and intend to use them together. Do i install them seperate. Commander then the chip....will the commander know the chip is there or is there a hookup from the chip to the commander. I saw the chip comes with a foot long wire, does this go to the commander somehow? Also, per the quadzilla commander manual it says "Connect the supplied wire to the wire in the middle of the connector (on the MAP). If you have a power module installed you will need to connect to the same wire on the modules wiring harness to receive an accurate reading. Only tap the wire of the plug that is going to the sensor. Tapping the factory wire when using a power module will result in a false reading."
**I am confused about this.....HELP!!!!! Thanks in advance for all the help!!! Hope this chip makes a difference!!! |
People, What year truck do you have?The map sensor conection doesn't work on the OBS trucks. I called Quadzilla and they said they might have an adapter soon.
oh my bad, 2001 f350 7.3......
Sorry People as I've never done a newer style truck. Maybe some will help soon or do a search on how to install. The chip will make a huge difference.As long as you have the EGT's and Trans temp that the most important.
