Injecting Meth/Water - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-11-2012, 06:15 PM Thread Starter
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Hey guys, I have the pump set to turn on at 10-11 PSI and be 100 Flow at 20. Does that sound good? Would you inject at a lower boost? Im running a single 625ml Nozzle, and Im thinking about getting the dual nozzle add on. Any comments/Suggestions?
So far, the spool...and power are VERY noticeable.....But it sure does dran my washer res fast!
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #2 of 4 Old 03-11-2012, 08:14 PM
steve's red stroker's Avatar
I'd bump starting to 14-15 and max at 25, you'll have to play with it, if you go to low of psi start point, you can put out the fire, it's safer with more boost IMO
steve's red stroker is offline
post #3 of 4 Old 03-11-2012, 08:22 PM Thread Starter
Winning DUHHH
Quoted: 8 Post(s)
Well with it starting at 10 I haven't had an issue yet....but ill bump it up 5..my only problem is that the controllers max boost value is 20 psi... Idk i thought itvwas supposed to go to 25
Sent from my PG86100 using AutoGuide.com App
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
post #4 of 4 Old 03-12-2012, 05:41 PM
My controller goes to 60, and I run two 675's, start at 20 and peak at 32
