AIH Delete??? - Ford Powerstroke Diesel Forum
Old 09-20-2007, 04:53 PM
AIH Delete???
I have bought a plug to replace the aih with and even drilled and tapped it to use for the boost gauge, but what do i need to do with the wires? just cover them with heat shrink tubing and tuck em outta the way or ????
just dont want do create any problems...Rod
Old 09-20-2007, 05:01 PM
Desert Shield/Storm Vet
The red wire with the plastic wire loom just take that off with the aih and your good to go
Old 09-20-2007, 05:03 PM
what about the other one??
Old 09-20-2007, 05:05 PM
Im wrong I just looked it up and here is the exact procedure:When removing the AIH you remove the red (hot) wire at the solenoid,
Black (ground) wire and Red wire from the AIH
Old 09-20-2007, 05:08 PM
International Threat
I removed both - you'll just get the 0541 code which means nothing. It won't set a hard code - so no SES light.
thanks for the info Vital...Rod
