ECU questions
When i was installing my new ts performance chip i unhooked the batteries but didn't tie the terminal back and it made contact as i was installing the chip now i think i fried my ecu
my ecu code is apx1 1c3f 12a650-yb and i cant find a ecu is there other ecu's that would work in my truck? If i get a used ecu do i have to have it flashed to my vin and milage and where can i get this done?
Why do you think your pcm is fried? Hopefully you didn't leave the keys in the ignition when you installed the chip, thats what fries the pcm.
the key was in the ignition and now i have no power to the fuel pump and no wait to start light. I checked all the fuses and there all good.
If i buy a reman computer do i have to have it flashed i found a reman ecu for $237
You'll be fine without having it reflashed, but it you want the most current program you'll want to have it done.
Have you tried to pull the chip off the PCM and see if the truck starts?
If you have, find a PMT1 PCM. You have an E99 truck I'm guessing? |
Check the fuses first in the box under the hood. if not I have a pcm that will work in your truck that I'll send to ya
I checked the fuses there good
Then you pcm is fried.. Mine has fired before.. Pm me I got one that will work in your trucks that I'll sale to ya for a good price.
Is the chip still on the PCM???
| Tags |
| computer, ecm, ecu, pcm |
