lookin at high performance injectors
what is a good brand of injectors for a 2001 7.3L that are priced at a reasonable price.
Full force, swamps, unlimited, rosewood. What is your goal for the truck? What mods do you currently have? Do you have pmr's? All these are important
I have a 4in turbo back straight pipe and a six position chip switch on the fly and a stage 1 airid. My goals for the truck is injectors garret ball-bearing turbo with a 88mm comp.wheel and ats stage 3 trany. What's is pmr's?
Powdered metal rods, you have an 01 so you might not have them, but prolly a 90% chance you do. I think you're referring to a garrett 38r for you turbo but the 88mm is the turbine wheel, compressor is 66mm. If you're dead set on an ats stage 3 then get one but i personally would never run one. If you go to single shots you will need custom tunin. Search on here for the steps to see if you have pmr. I could tell you but you'll prolly need pics
types of injectors, which one for me? 38r turbo ------this is a link that will tell you how to look to see if you have pmr
I'd look at BTS before the ATS trans.
what years where the pmrs in? forged?
Pull the inspection to figure out for sure what you have. But there is a thread with serial numbers saying what has what. And it's been right so far.
Thanks Sent from my ADR6350 using AutoGuide.com App |
