38r help - Ford Powerstroke Diesel Forum
Old 02-24-2012, 07:00 AM
38r help
I just got a 38r and im really excited to install it but I was wondering if there's any tricks to getting the back clamp that holds the Turbo to the up pipes off? Also how do you take the ccv off?
Old 02-24-2012, 07:26 AM
spray some dope on it and whoop the piss out of it. to remove the ccv you just take a piece of 4'' exhaust and put it where the plastic piece was, remove the doghouse from the valve cover, flip it 180 and run a hose to wherever you want
Old 02-24-2012, 08:22 AM
Haha that's what I figured but thanka for reassuring me
Old 02-24-2012, 01:47 PM
That back clamp is a royal pain. I have had the best luck with a small screwdriver and working it under the band. Lube and a hammer worked for 2/3 of the clamp but it has three V sections and the one that I couldn't get a hammer on stuck.
Old 02-25-2012, 11:17 AM
I got it installed and its pretty bad a$$ but im only running like 8-10lbs of boost, how do I elevate the boost unplug my waste gate?
Old 02-25-2012, 11:52 AM
Coal Rolling = Posing
You have a boost leak somewhere most likely. Go over every clamp again and make sure they're properly seated.
I'd bet one of the clamps between the spider and the intake plenum didn't get snugged up just right, or you'd have blown the boot off and found the problem already.
Old 02-25-2012, 11:56 AM
Thanks for the feed back, I'll have to check it out
Old 02-25-2012, 11:59 AM
How are you reading boost?
Old 02-25-2012, 12:09 PM
Mechanical issopro gauge. I have a t fitting in my map line
Old 02-25-2012, 12:13 PM
Cool, make sure the MAP line has a good connection on each end too, and that the "T" is still properly installed in the line.
Are you running tunes? Black smoking at full throttle?
