tuners
I have been out of the game for a while and now looking to upgrade my current tuner. I have a TS 6 position chip now and looking to go to something a little more custom and geared for towing. I usually tow around 7 to 10k and am in new mexico which is mostly mountain driving. I will be upgrading turbo and injectors soon, as for now i have 5in stacks, tom woods valve body, 6637, the itp pick up and pre pump filter, carter lift pump and waiting for my new ebp sensor and tube as well as an ICP sensor as they have failed. I currently get 11 mph no matter if im empty or pulling. I have 35s and a 4in lift i know its not the best set up for towing and mileage but i like it and will be staying with the lift and tires. I had always wanted to get a DP tuner but with all the new guys out there im wondering who has the best tuning for towing at this point as well as any turbo (38r maybe?) and injector suggestions as far as bolt on turbos and injectors i can run with stock oil or maybe Adrenaline. Thanks in advance for all the help.
My personal suggestions (just use it as a gauge) is Stage II injectors (160/100) SRP1 HPOP, GTP38R turbo and a PHP chip. That should make about 400-425 HP.
i made a lot more than that. i was live tuned but i made quit a but more
what year is your truck
You're right, just depends on tuning.
My truck is a 99.5 with 170k miles
what makes php tunes any diff than the ts i already have
Bill has been in the tuning game for several decades. He understands what our trucks need, and writes great tunes for them. He wrote the tunes for Edge back in the day, then realized he can do better, so he opened his own shop.
Get With Jonathan Jones @ Bean's Diesel Performance in Woodbury TN, I promise you, you will not regret it...I'm running an early '99 PSD w/ Bean's Stage 2 Injectors, Bean's Dominator 66mm Non Wastgated Turbo, Bean's In Tank Delete Sump Pump, Walboro High Flow Pump Frame Pump, & a TS 6 Position custom tuned by Jonathan, and I'm hitting 460HP, 1100FTLBS, & 35LBS of boost alllll day long.
ive been pretty happy with Wildman
