deep pan - Ford Powerstroke Diesel Forum
Old 02-19-2012, 04:46 PM
deep pan
i was told the deep pans use a filter spacer. is this true
Old 02-19-2012, 04:52 PM
Govy Magnet
Howdy! What deep pan are you talking about, my guess is that its the transmission deep pan. If that is the case NO it does not need a filter spacer, but I would do a 6.0 tranny cooler before a deep pan, the benefits will be much greater that way. Also an external filter kit is always nice.
~Phil
Old 02-19-2012, 04:55 PM
The Tamed Racing Driver
^^^Agree on the 6.0 cooler
Old 02-19-2012, 04:56 PM
i didnt think it needed one thanks
Old 02-19-2012, 05:23 PM
yeah im not spending 300+ on a 6.0 cooler
Old 02-19-2012, 05:27 PM
Its a much better bang for your buck as far as keeping the trans cool when compared to a deep pan. I've heard a few people notice no difference in trans temp after switching to a deep pan.
Old 02-19-2012, 05:28 PM
ijust found a tru cool cooler 12x11x34 gvw 22,000 for 76 bucks thats a better why to go in book
Old 02-19-2012, 05:31 PM
i have heard the same thing but the more oil you have less spikes in temp
Old 02-19-2012, 06:27 PM
Govy Magnet
I was just saying that the better cost is spent on a different cooler. I did the deep pan first and noticed literally no difference in temps maybe 10 degrees at best. When it rained I did notice a huge difference. The only reason I say the 6.0 tranny cooler is the best alternative is that it makes a massive difference, my transmission since the install has not seen above 165 degrees! That intense but I do want to see what it will do int he summer...especially out here. Just saying if you are spending over 100 dollars on cooler parts, just save up and get a 6.0 tranny cooler. Also the added fluid costs a lot more, I believe its 7 qts more than normal, and that is definately a large influx in $$$
~Phil
Old 02-19-2012, 08:02 PM
i understand what you were try to say but i think the 6.0 cooler is over price and theres better ones out there for less and the deep pan 7.5 qt bigger you only changeevery 30,000 miles so it won't be that bad. my set is going to be deep pan then the bypass filter which will give me alittle extra cooling the change out the stock cooler to tru cool 12x15x3/4 cooler then see how long the tranny well last, i'm trying the make the tranny to last as long it can and maybe jon woods vb
