Turbo lag? - Ford Powerstroke Diesel Forum
Old 02-17-2012, 08:51 PM
Turbo lag?
OK when I'm going down the road the truck goes into overdrive and just seems to die. And when I give it more fuel to shift Down and go I can feel the Turbo like it should be. The only thing for the truck to feel healthy is to crank my chip up.
The truck runs great otherwise. I know i have leaking up pipes and no boost leaks. Is this normal what I'm feeling?
Sent from my DROID RAZR being lazy
Old 02-17-2012, 10:08 PM
Depends on what speeds but it sounds completely normal to me.
Old 02-18-2012, 06:45 AM
Thank you. Like between 45 and 55 the truck seems dead while in overdrive. After that you can literally feel the boost build. I don't have my gauges in yet( waiting on my pod) but maybe those will help to see if i have a lil problem.
Old 02-18-2012, 11:00 AM
At that speed your truck sounds completely normal to me.
Old 02-18-2012, 01:46 PM
With the up-pipes leaking it will take a bit more throttle to spool the turbo. In overdrive your wastegate is dumping most of your boost anyway. When you fix your up pipes look into bellowed up-pipes. Wish I would have known about them before I replaced my up-pipe gaskets.
Old 02-18-2012, 02:23 PM
Appreciate the advise, I've worked on 7.3s for years I guess i never noticed it until its my own haha. But yes as soon as i get some funds up I will be replacing and upgrading up pipes.
Sent from my DROID RAZR using AutoGuide.com App
Old 02-18-2012, 03:57 PM
I actually had the same problem while hauling a trailer once. Figured out that I had to wait for the "wait to start" light went off before I cranked.
