highest safe towing power level
what can i do for a shopping list to put on this truck towing a 12k fifth wheel. when truck gets paid off i can mod the motor. I want to go as high as i can
towing power level. The trans is bullet proof so that dont matter. this is a 99.5 for year |
Well start off by opening up the intake setup and exhaust. Maybe install a full 4" turbo back exhaust, as for intake, just depends on how much you wanna spend. You can get a afe setup or get a diy intake installed. Then after that, order yourself a custom tuned 6 position chip for your truck. Just make sure you let them know you wanna do some heavy towing and they will set you up with a towing tune on your truck hopefully keeping your egt's down alil bit while towing that much weight.
As previously stated DIY (6637) intake, 4" turbo back exhaust, and a custom tuned 6 position chip. I suggest PHP but there are lots of great options out there. Also a set of gauges are a must. Pyro, boost, and if you have an auto, a trans temp. Hope this helps.
i have dual 4 in stainless exhaust, brute force intake and a bullet proof trans wanting to spend up to 15k. i did the hutch mod the harpoon mod and the intake mod fuel line. zoo dad mod
![]() In that case: Stage II 160/100 injectors SRP1 HPOP GTP38R Turbo Valvesprings ARP headstuds Fuel bowl delete with regulated return Hutch/Harpoon mods Nice custom tuning (PHP, TW, Beans etc) That should add just a little bit haha. |
air, fuel, oil.
GTP38R turbo injectors-1s or 2s T500 or stealth or SRP1 HPOP those are the basics |
Meth can help your egts while towing
so whats the highest horse power level for my truck towing.
You can tow with any horsepower...
I'd stick around 400-450 though personally. Just watch your EGT's. Sent from my Autoguide iPhone app |
I wish I had 15K to spend
![]() I can already see my wife when she sees the UPS truck again ![]() ![]() ![]()
