Agressive Stance? - Ford Powerstroke Diesel Forum
Old 01-25-2012, 09:24 PM
Question Agressive Stance?
I want to keep my stock rims but i also want the tires to stick out a couple inches from the body and have a nice aggressive stance? is this possible? what size tires would i need in order to achieve this stance? thanks for any input guys.. I'm a noob when it come to tires and rims. would i need wheel spacers or could i simply mount a wider tire?
Old 01-25-2012, 10:25 PM
A wider tire wont do much for you.. a wheel with a higher negative offset will do it.
For example: -12=close to stock
-40 sticks out a couple inches past the wheel well. I just used some numbers I remembered when wheel shopping..
As far as spacers, a 2 inch spacer should give you what you want but be sure to go with a steel spacer and not aluminum. Theyre not exactly cheap either..
Check the swap meet section, there's usually someone on there looking to trade plus a little cash..
Old 01-25-2012, 11:38 PM
I say if you have to spend 200 on spacers just spend 250 more and get rims. Jmo
I wouldnt like the idea of 2" spacers but i will have heavy loads on my truck. That would be the point that i would nervous about them.
Since this is kinda on the subject of the thread...has anyone had good/bad experience with a spacer like this?
Old 01-26-2012, 06:04 AM
2" spacers did just what I wanted with 08 20's on my 99.
Keep in mind the 08 rims are zero offset.
Old 01-26-2012, 03:57 PM
where did you buy your spacers from?
Old 01-26-2012, 04:14 PM
nevermind your right F the spacers there toooo expensive i might as well get rims. Can i get a decent set for around a grand?? what do yuo guys think would look good on a white reg cab long box???
Old 01-26-2012, 04:23 PM
I've got a crew cab short box with 17" weld racing wheels. And a -40(?) Offset. Look pretty good IMO.
Old 01-26-2012, 04:48 PM
Old 01-26-2012, 06:49 PM
Well, most aftermarket rims don't really look that great.
IMHO...
Old 01-27-2012, 04:40 AM
i picked up my rims on ebay for 860 + shipping
