MPG again - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-12-2007, 12:27 PM Thread Starter
MPG again
I have a 2003 F350 7.3L LWB 4X4, I'm running 295 75R 16 tires, larger, but not really big. My mods are and AFE intake, and a 4" turbo back exhaust, and an ARE bed cover. I don't push it much, and generally keep it under 65mph. I'm getting barely 17MPG, and 12.5MPG when towing my travel trailer(a 30 ft ultralight) I'm pleased with the towing MPG, but I've heard so many say the get about 20MPG unloaded. Is this normal, or should I be getting better? I'm thinking tuner, but haven't gotten one yet.
Thanks
Stressed
Stressed11
2003 F350 CrewCab 4WD SRW Long Box
7.3L, AFE Intake, 4" Turbo back exhaust, 4" Lift ARE bed cover
Stressed11 is offline
post #2 of 9 Old 09-12-2007, 12:30 PM
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
keep driving it. Break it in blah blah you know the story. 17 aint bad i guess... people are getting worse than you lol what do expect... you got a BIG AZZ TRUCK
lifewitlooie is offline
post #3 of 9 Old 09-12-2007, 12:30 PM
COLLEGE KID
myth busters did a tonneau cover test and they said NO Cover TAIL gate UP is better for MPG than the cover.
post #4 of 9 Old 09-12-2007, 12:31 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Also remember unless you reprogrammed for tire size your getting a bit better mileage then your computing
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #5 of 9 Old 09-12-2007, 12:35 PM
A tonneau cover usually helps mpg's...
the mythbusters tested tailgate up/down and with it down was less mpgs.
most trucks seeing 20 mpg also are 2wd - not 4wd - so I'd say you're doing well!
Blue01F250 is offline
post #6 of 9 Old 09-12-2007, 12:39 PM
rookie_j's Avatar
i was just going to say the same thing. i remember in the late 70's everyone was running their trucks with tail gates down to get the extra mpg...
for mythbusters..
P.S. last fill, 17.4 mpg freeway with cruise set at 71 mph, running empty (maybe if i took off the bed cover off i could get 24 mpg)?
99 F250 4x4 CC shortbox
7.3
Guages; Pyro & Trans Temp
DIY Intake
farmboydiesel 4" turbo back
aint it pretty? sure do wish my wife would let me drive it
rookie_j is offline
post #7 of 9 Old 09-12-2007, 12:52 PM
I have an ARE hard tonneau cover and I swear that I get better mileage on the highway without it. On a trip to the Outer Banks, I averaged around 19 mpg on the highway. Without the cover a few weeks ago, I traveled about 200 highway miles and got a little better than 20 mpg using the same driving methods.
To each his own, this has been my experience.
720Deere is offline
post #8 of 9 Old 09-12-2007, 03:08 PM Thread Starter
Well my cover was bought for looks and not for MPG. Yes it adds weight, and maybe doesn't help with mileage. The thing is I thought the other mods I have were supposed to help with the MPG and performance. I seem to be getting the same mileage as those with out the exhaust and intake. ?????
Stressed11
post #9 of 9 Old 09-12-2007, 03:11 PM
vitalidle's Avatar
With your tire size factor in your going 2 mph faster then what your spedometer says, so you actually going farther then what your odometer says.
Auto 93,000 miles
DP Tuner F5
