Looking for more performance
so i think im ready to start getting more done to my Early 7.3L 240k miles
I drive the truck everyday and, also plan on keeping her for a while... Don't Get me wrong it smokes cars now but i want to stay in front What's done: 6" lift on 37's Bank's Big Head turbo actuator Voodoo Boost Controller 6637 Intake Trans Work- Heavier Clutches/Billet Torque Converter 4" Turbo back to stacks Glow Shift Pillar Gauges - Pyro/Boost/Trans TS with Tony Wildman Custom tunes What im debating upon and would like opinions: Stage 1- 160CC injectors FRx / HPx Harpoon/Hutch Mod let me know if theres other things i should be focused upon thanks Last edited by sean400; 01-25-2012 at 11:57 AM. |
if you do tow alot you could regear it that'll make a pretty decent difference
yeah i tow pretty frequent but wouldn't want to be doing 80 pinging the rev limiter, she'll break em loose with ez. thanks for the input tho
with 37s regearing it makes it the equal of a stock truck. right now on your truck with 37s the end gear ratio is probably in the low to mid 2s regearing it to 4.10s even is going to get that closer to stock gear ratio. the tires create your final gear so you wouldn't be pegging the rev limiter at 80 it be the exact same as a stock truck.
ok i see, ill look into that
some reason i thought 4:10's would lower my mpgs and top speed... shimming gears isn't that bad
Dont change your gears... Worst mod I ever did was change to 4.30 gears.
i've never heard anyone complain about that. when i did that on my dodge gasser it changed its acceleration and everything alot. and it is alot easier on your transmission.
kinda what i was thinking
The only time its better is when I am crusing around town, otherwise the 3.73's were MUCH nicer
