Have a Question - Ford Powerstroke Diesel Forum
Old 01-18-2012, 01:11 PM
Have a Question
Just wondering have a friend that told me about someone putting a resistor in their fuel pump and he said it makes it lope like a motherf'er. Didnt know if anyone could help me out on if you can do it on a 7.3L and about to add a FASS system will doing that affect the FASS system? If you can let me know how thanks...i know how to put one into the ICP sensor but i wanted to try the one in the fuel pump or is putting one in the ICP sensor safer?? THANKS!!
Old 01-18-2012, 01:51 PM
There is nothing you can add to the fuel system to make it "lope" ie run like ****...
Your friend is confused.
Old 01-18-2012, 01:59 PM
well i have heard from two different friends that they know of two trucks that have a resistor on the fuel pump somewhere wired into a switch that will make the truck shake it lopes so bad
Old 01-18-2012, 02:09 PM
Let me explain the 7.3 fuel system to you...
You have a fuel pump...
It gets 12v when you turn the key on. It stays on all the time when the truck is running...
It pumps to the fuel bowl which then goes to the heads. On the return line there is a mechanical regulator that keeps the pressure at 50-80psi.
There is NO way to add ANYTHING to the fuel system to make your truck lope.
As I said before, your friends are incorrect.
Old 01-18-2012, 03:34 PM
It's Not the fuel pump, but the HiPres oil that drives the injectors that can be effected with a resistor, CSIPSD is right - you ARE confused
You should find other people to listen to about your truck
Old 01-18-2012, 03:57 PM
Custom tunes will do the same thing I had it on my php Fu used it once or twice but it got old fast
Old 01-18-2012, 04:04 PM
I'm not confused that's what a couple of my buddies told I know that you can put one into the ICP sensor that makes it.......I have to get ahold of the guy that supposedly has it and get back to you guys
Old 01-18-2012, 06:52 PM
Get back all you want, there is nothing you can add to the fuel side of our trucks to make squat differance.
Old 01-18-2012, 07:22 PM
spool up that turbo!!
Are talking about the idm 10k mod? It's useless buy a chip and be done with it
Old 01-18-2012, 07:47 PM
If you put a resistor inline with the fuel pump you will lower the voltage at the pump causing it to spin less rpm which will cause it to pump LESS fuel.
Maybe they are starving the truck for fuel which makes it run like azz???
