Tow - Haul - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-11-2012, 08:33 AM Thread Starter
SoTX's Avatar
Tow - Haul
Does anyone make a chip or programer that will mimick the Tow Haul function on the newer trucks.
E 1999 F250 4x4 Crew Cab short Bed
4R100 automatic
7.3 PSD
2" lift
6.0 Transmission cooler
Glow Shift gauges on pilar, trans, egt, boost
35's on 17's
RiffRaff RDP 6637 Filter Kit intake
4" MBRP exhaust
South Texas Outfitters:
50 gallon custom fuel and tool plumbed direct
Heavy Duty rear bumper
Custom heavy duty front bumper
headacke rack
Fender flares
Rhino lined all add ons
Rhino lined rocker panel
High lift Jack
SoTX is offline
post #2 of 5 Old 01-11-2012, 08:56 AM
CSIPSD's Avatar
Press the OD off button...
What are you looking for?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 5 Old 01-11-2012, 09:02 AM Thread Starter
SoTX's Avatar
I have a E99 and in my newer PSD's they have the tow haul function where the transmission will down shift through the gears slowing you down when you tap the brake pedal. So say you are towing a heavy load and the traffic light turns red, you simply tap your brake and the transmission will down shift like if you were driving a standard shift vehicle. On the older trucks you only have brakes to slow you down.
4R100 automatic
7.3 PSD
2" lift
35's on 17's
4" MBRP exhaust
headacke rack
Fender flares
High lift Jack
SoTX is offline
post #4 of 5 Old 01-11-2012, 01:52 PM
Jokester's Avatar
buy a 6 speed.
2001 F350 Lariat 6 speed, South Bend clutch. 4inch turbo back, Tymar intake. Garrett GT38R. Swamps 175/146 injectors. Driven regulated fuel return. TS 6 Position Swamps Tune.
Jokester is offline
post #5 of 5 Old 01-12-2012, 04:15 PM
2000 F550 DRW. 4x4 manual Trans
AIH delete
Glow shift guages
98gal transfer flowtank
Riffraff 6637 kit
Ccv mode
Wicked wheel
4" mbrp
PAC brake with aux air tank to air stuff up
TS chip 6 pos
Riffraff hpx crossover
Vdryv is offline
