quick question on oil filter - Ford Powerstroke Diesel Forum
Old 01-06-2012, 11:22 AM
I am about to order an Donaldson ELF 7405 oil filter, since there primarily on cat diesels i called up my local cat dealer, had to cross reference the Donaldson filter so cat has too difference filters the p5504005 at 118mm and a p554105 at 135mm they have the 135mm in stock right now and they say its the larger capacity, i need to know or make sure that this one is going to fix and work with out leaking all over the place... any help would be great thanks
truck is a 02 f350 7.3L
Old 01-06-2012, 02:38 PM
Don't think it will fit, get the Donaldson
Old 01-06-2012, 03:21 PM
This is the Donaldson filter but it has too different sizes 118mm and 135mm
Old 01-06-2012, 03:24 PM
Find my BHOF thread. I've been doing research and the one that is the 'original' BHOF is the biggest one that will fit.
Old 01-06-2012, 04:23 PM
BHOF
Old 01-06-2012, 05:14 PM
There ya go. I was just hungry and wanted to eat instead of searching for it
Old 01-06-2012, 05:23 PM
No worries! Had that one saved.
Old 01-07-2012, 05:05 AM
where is the best place to order these online?? when i talked to cat they cross referenced it with there donaldson/ cat p5504005 filter but it was a standard not a extended life so i am just going to have to order it online because i seem not to be able to find anyone around here that sells them
Old 01-07-2012, 05:12 AM
Send a message via AIM to rufushusky
Ryder seems to have them for the cheapest....
Oil filter, ELF7405, Donaldson
The ELF7405 is 118mm (a littler under 5") and is pretty tight against the pan.
Old 01-07-2012, 05:22 AM
hey thanks for your help, this donaldson filter thing is starting to become a pain in the *** and it really shouldnt be... the ryder site that you just sent me says i need to buy 6 of them at one time...
