Question on Superchips and TS - Ford Powerstroke Diesel Forum
Old 01-05-2012, 07:41 PM
Ok i have a TS 6 position with custom tunes and i noticed the other day that my truck tops out at 105-106. Is there any way possible since the superchips you can remove the speed limiter that i could unplug my TS, and plug in the superchips that if i go in and leave the superchip on stock but remove the speed limiter if i could then plug back in my TS and if the speed limiter would still be removed?? Need help dont want to try and it mess up my TS.
Old 01-05-2012, 10:14 PM
is you mean 105mph then id leave speed limiter alone. at that speed your rpms get up to high and you run the risk of rods going through to block
