turbo silencer - Ford Powerstroke Diesel Forum
Old 09-08-2007, 03:54 PM
turbo silencer
is there one and can you remove it???
Old 09-08-2007, 04:02 PM
Desert Shield/Storm Vet
Remove the foil insulation on the drivers side intercooler pipe.
Old 09-08-2007, 04:17 PM
oh ok I thought it was something in the piped that would restrict the air flow
Old 09-08-2007, 04:29 PM
If you want your turbo to sing louder you can add the whicked wheel and remove the foil insulation. You already have an open intake so that is about all you can do to a stocker to make more noise other then adding a ATS compressor housing also.
Old 09-10-2007, 10:07 AM
thatlk vitalidle is the wicked wheel a pain or doable I dont really like to take my truck in. I like to do my one work
Old 09-10-2007, 11:37 AM
Sure is. You have two options basically you can install with turbo still on truck, or pull the turbo and do it on the workbench. Certainly pulling the turbo is a little more work, but very doable I can give you some links for each option if you want them. Im at work till 10 pm eastern time, but when I get home I will post up the links for you.
Old 09-10-2007, 01:27 PM
Remove the hood for full effect...
Foil delete
GT38R install
AFE Stg11 intake
5" staright pipe exhaust
