03 7.3 - Edge Evolution CTS won't work.... - Ford Powerstroke Diesel Forum
Old 12-24-2011, 03:44 PM
I just got this programmer yesterday and decided to install it today before a long trip tomorrow. i hooked it up as described in the directions, it asks me for the model of the truck, it takes me through the key on/off cycle and then it has me enter the VIN number. After entering the VIN number, it gives this error:
Vehicle Communication Error - Error reading file IDS during VIN write.
it does this every time, about 12 times so far.
Anyone ever had this??
Old 12-24-2011, 04:05 PM
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
I'd call edge and tell them what is happening
Old 12-25-2011, 08:49 AM
I emailed Edge, they said it does this when there is a chip installed on the PCM.... which there isn't, but i took it out and confirmed anyway.
I have the best luck.... hopefully i can get this resolved quickly after the holidays.
Old 05-25-2012, 09:44 PM
Hi I have the same problem Have you managed to fix it as yet
Old 05-28-2012, 02:47 PM
yes, 27 emails later and several updates, they finally have a fix. I would call them or email tech@edgeproducts.com
They will send you a file that you will have to download and update your programmer. i went through several versions with them and they finally got it to work. it takes a long time to download, update, and program your truck. make sure you've got some time on your hands, it isn't a 15 minute process.
Old 11-04-2012, 05:29 PM
Do you still have the file? I have the same problem.
Old 11-05-2012, 05:21 AM
You have to contact them. The file will be sent to you through their update program for your tuner. It takes a long time with a fast connection, so i'd plan on having a few hours to run it.
It's worth it though.
Old 11-05-2012, 07:03 AM
If you can get me your serial number on the device I can set up the download for you.
