Upgrading my turbo -which one? - Ford Powerstroke Diesel Forum
post #1 of 64 Old 12-22-2011, 06:30 AM Thread Starter
Fordgirl89's Avatar
So my project for the winter is putting 238cc hybrids and an upgraded turbo in my '99 7.3. The problem is I have no idea what I should choose for a turbo!
Right now I'm looking at maybe doing a 38R garret turbo but was wondering what you guys thought for other options and why. The truck is mostly a daily driver but I sled pull with it all summer long. The truck currently has a TS 6-postion with PHP tunes, and intake and exhaust. I do eventually plan on putting head studs in it but that probably won't happen until next year.
'99 F350 xlt eclb srw auto 7.3 4x4: S&B, 4" Flowmaster, A-pillar gauges, TS 6position w/ PHP, HPx, Wicked Wheel, 33" Destination M/Ts*2011 MATPA Street Diesel champion!
'95 F250 xlt rc srw auto 7.3 4x4:260cc inj, K&N, A-pillar gauges, fass, T-500, BD modded turbo, Boost fooler, TS 6position, modded IDM, traction bars, 35" Fierce Attitudes, 8" mitre cut, D60
'02 F250 lariat ecsb srw 6-speed 7.3 4x4
Fordgirl89 is offline
post #2 of 64 Old 12-22-2011, 06:44 AM
Eric@PTP's Avatar
Is it an early 99 or a 99.5 ? If its a early 99 you cant just bolt on a 38R, the early 99's basically have an OBS motor. You would have to swap parts like the up pipes, turbo mounting flange, pedestal, intake spider, intake manifolds off of a 99.5-03 7.3 motor ( I think there is some other parts too but I forgot ) to get a 38R on there.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #3 of 64 Old 12-22-2011, 06:54 AM Thread Starter
Fordgirl89's Avatar
Nope its a 99.5
post #4 of 64 Old 12-22-2011, 07:25 AM
Eric@PTP's Avatar
Originally Posted by Fordgirl89 View Post
Nope its a 99.5
Oh okay so your good then, we have them on sale right now you might want to take a look and shipping is included in that price.
1-888-516-4644
GO NAVY
Eric@PTP is offline
post #5 of 64 Old 12-22-2011, 08:05 AM
sniper_101's Avatar
Could also consider a T4i style mounting system. Would open your possibilities of turbos up to a whole new level, especially if you plan on shooting for even more power in the future.
As far as drop in's, the 38R and by the sounds of it, soon a new drop in from Precision better than the 38R (I don't know much about this new turbo other than that).
2000 Ford F350 XLT - Supercab Shortbox - twin stick
1988 GMC Sierra
1994 Ford Ranger
2006 KTM 525 EXC-R - steet legal supermoto/dirt bike
sniper_101 is offline
post #6 of 64 Old 12-22-2011, 03:54 PM
yeah i've had 38r and and now run an s366 and thats what i would recommend. after you buy a 38r with bellowed up pipes, non ebpv pedistal and high flow outlet you could have a s366 sittin on irates t4. much better design with ease to grow. i would even try the s467 with those 238's. other good turbo would be the gqssb from wop. doesn't look like youre gonna have those 238's turned up very high if you don't plan on studs. studs, valve springs, pushrods, fuel system, tranny. but thats just my input
bruce51d is offline
post #7 of 64 Old 12-22-2011, 04:44 PM
CSIPSD's Avatar
The only thing to consider is your tech when you pull... You will more then likely get bumpped with a T-4 type turbo... a 38R might pass as a stocker and you can still pull in the normal class for your area.
T4 or T4i kits are HEAD and SHOLDERS better then a 38R otherwise.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #8 of 64 Old 12-23-2011, 08:56 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Best...IMO modded H2e...we have a kit complete with bellowed uppipes..PM if I can help.
Cary
CT Performance, Inc. is offline
post #9 of 64 Old 12-23-2011, 09:34 AM
Quoted: 3 Post(s)
Cary
just for my info, better than an s366 ?
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #10 of 64 Old 12-23-2011, 10:17 AM
Quoted: 3 Post(s)
I haven't a clue..never see any specs most posts I have seen have been on stock inj's.... usually see varaitions of it sometimes as Dodge or Dura guys use them..
