intake plenum - Ford Powerstroke Diesel Forum
Old 09-06-2007, 06:46 PM
intake plenum
How hard would it be to change out the intake plenums just the way the truck sits? I am want to put on the BDP alum. ones with a late 99-03 spyder then maybe a D66
Old 09-06-2007, 07:11 PM
just a bump before it falls off the main page
Old 09-06-2007, 07:53 PM
Not bad, some of the bolts are hard to get too... and you will need to pull the turbo and I think the fuel bowl... Otherwise about a 3 hour deal. Dont expect any huge gains, maybe a silghtly lower EGT...
Old 09-06-2007, 08:15 PM
I take you done it time or two.
Old 09-07-2007, 12:55 PM
lukecline
Guest
Posts: n/a
im pretty sure you cant get to all of the passenger side plenum bolts w/o removing the hpop.
Old 09-07-2007, 02:08 PM
Also the D66 is for OBS and early 99's
Old 09-07-2007, 10:53 PM
mine is a early 99
Old 09-08-2007, 03:36 AM
I wonder is the the high HP guys (like 400+hp) are running aftermarket intake plenems, or are the factory plenems sufficient?
Old 09-08-2007, 11:09 PM
Im running the factory ones on both of my trucks.
Old 09-09-2007, 07:52 AM
lukecline
Guest
Posts: n/a
Im running beans billet plenums. With high boost its hard to keep the boots on the stock plenums. If you over tighten the clamps the plenums can crush.
