blocks in the rear? - Ford Powerstroke Diesel Forum
Old 09-05-2007, 02:23 PM
Send a message via MSN to Jesse.James
blocks in the rear?
I put 1 1/2 inch blocks under the rear of my truck the other day, i put them on top of the factory blocks. I was wondering if it matters whether they go under the factory blocks or on top? thanks.
Old 09-05-2007, 02:43 PM
im fat and ugly
i dont thhink it really matters
Old 09-05-2007, 02:50 PM
International Threat
I don't think it does either - but I would look into getting ONE block made that is the correct size or buying a small rear spring lift. Stacked blocks aren't a good idea.
Old 09-05-2007, 02:59 PM
im fat and ugly
what i did was tack welded mine in several places to keep from any worries
Old 09-05-2007, 03:20 PM
COLLEGE KID
Send a message via AIM to lifewitlooie
you shouldnt worry about it to much at all. just torque those U bolts down tight every few hundred miles and its all good.
Old 09-05-2007, 05:41 PM
Been running stacked blocks for over 500k on two trucks with no issues... Nothing to worry about!
Old 09-05-2007, 05:56 PM
as llong as the blocks arent wedged it wont matter. the fastory blocks usually have the bump stops. so I would put the bump stop (factory) blocks on top so your tire wont ever get into your fender.
Old 09-05-2007, 06:57 PM
out of curiosity...are blocks used in these trucks 2.5" or 3" wide? And would the low side of a tapered block be torward the front of the truck or the rear?
Old 09-06-2007, 07:18 PM
Were do you get blocks for the rear? if i do that and a leveling kit will the truck be noticbly taller? what combo would work for that?
Old 09-09-2007, 06:55 AM
The thicker side of the block goed to the front. This will kick the axle up so it gives you a better pinion angle and not be so hard on you u-joints. So the wedge goes on bottom and thinner side goes to the front on truck
