I have a set of autometer c2 gauges for my truck that I'm trying to install. Where can I get an electronic sender for the transmission temp gauge? My truck has no sending unit to begin with, and the harness for the gauges has a 2 port female clip on it not a ring connector. Where would it get put into on my e99 4r100?
It shoulda included on with just a threaded post and it installs in the test port. Check dieselmanor for install instructions, they have pictures.
Not sure what kind of connector/probe is supposed to be used with it. Mine came with the plain probe with ring terminal.
Well one is going to be hot, one neutral.
Could you find that harness on the autometer website?
You're still going to have to get the temp probe, install it in the test port (very easy), and then you just need to use one wire because the probe is already grounded.
They show a two wire harness, but this is what I used and came with the gauge: Auto Meter
Didn't think to ask, is this a full sweep electric, half sweep electric, or mechanical gauge?
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
