performance
I was woundering where i could buy a boost fooler. Also i would like to know if anyone makes a chip that i can change the levels and have the last level as a "smoker" setting just so it will blow loads of smoke. Any other cheap performance ideas for me? or anything else i could do? I have a 2000 F350 7.3 with a stage 2 intake, gauges, edge evo, a banks big hoss waste gate, and exhaust. I want it to smoke and i also want to beat all these little ricers that mess with me.
Look at ITP Diesel, L.L.C. for the boost regulator
and Dp Tuner or Elite Diesel.* Welcome to the Elite for the chip You cant stack the chip with the edge evol, but the edge 10k one you can... Cant place the name right now... |
You can spend $45 for that fooler or spend less than $1 for a 4.7 volt zener diode and wire it into your map sensor. Only takes about 10 minutes to do and works great!
or dfuser.com
or you can forget the diode and spending $45 on one from those sites and go to a hardware store and make one for $5.
I had the evo on my old truck first. Got rid of it and went with a dp tuner, It was a lot of difference, and being able to switch on the fly was awesome! I also paid less for the DP than the evo! Only got stock, the 80 econo and 120 race. Got pretty good smoke out of the 120 but he has a 140 smoke if ya want to kill mosquitos
I think youd be happy with chips from either of the links CSIPSD posted. I have heard Tony Wildman does a great job too. I also recomend getting a BTS valve body before the chip. It really firmed up my shifts and saved the tranny some. You should be able to pick one up for around $250. |
where could i get a good valve body? also would you recommend anything else while im there? also could you include any websites and prices if you could. also how would i make a zoodad and a boost fooler? what does it all take? could it harm anything? would a tc lock/unlock be a good idea?
The problem with adding a resistor to fool the Map sensor is it makes it fuel in the highest fuel tables, killing milage and making it impossable to run any tests... For a Valve body look at a BTS valve body.
I have a TC controler from SP Diesel, one of the best on the market if you ask me... Runs off the cruse buttons and is fully ajustable and automatic... www.spdiesel.com |
A 4.7 v Zener diode is NOT a resistor. It will allow the 0-5 volt map sensor work normally from 0-4.7 volts then it will stop it at 4.7 instead of letting it go all the way to 5. This way the computer sees boost pressures from 0 to around 17 psi but will not see anything higher. It had absolutely no affect on my mileage and has worked well on all the trucks I have installed it on with no more service engine lights or defueling problems. You are right though, a resistor is not a good idea, I’d rather have a mechanical regulator than a resistor but a Zener diode is cheaper easier and more reliable than a mechanical regulator. None of these things are needed if you are not having defueling problems with hot chips or programmers.
