Just wondering what all is the same between a 94-98 psd and a 99-03 psd. Can I take a motor from a 97 and bolt my accessories on it and put it in my 02 SD? Also they have forged rods correct? What I'm trying to figure out is can I buy a motor from a 97 and over time build it then put it in my 02?
Well I found a 97 psd I can get cheap a good running motor. I was wondering if the block and heads and bottom end are the same. I wanna build it over time for the 500hp range then drop it in my 02. I was just wondering will it all match up or is it different somehow?
if you are building it over time id use the bottom end of the obs motor for the rods and put on a different turbo and a bigger hpop that the 15* if your doing a motor swap its not much more to swap the stuff onto the new block and heads. just my .02
Yes, the block and the heads are the same and would work in a later year truck. Only thing different on the heads is intake runners, but they can be swapped rather easy. You would need to switch the oil pan, front cover, HPOP, fuel filter housing, and turbo and pedestal. Basically all the accessories.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
