Too much boost? - Ford Powerstroke Diesel Forum
Old 09-01-2007, 09:42 PM
Too much boost?
How much is too much boost? I have a 2002 ford powerstroke, and the only modifications i have to my turbo is a banks wicked wheel. My truck puts out 32lbs of boost is that too much for my stock turbo, will it last?
Old 09-01-2007, 09:44 PM
32 should be fine
Old 09-01-2007, 09:48 PM
is that good, i mean i know it is way better than stock but what do most trucks on this site run?
Old 09-01-2007, 09:52 PM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Rule of thumb is try to keep it under 30 on the stock turbo. Can you go over 30psi, yes...but it isn't going to last as long as it would normally, and the turbo is pretty inefficient above like 25-27psi. I used to hit about 31psi....but now I'm back down to 25-27psi....and it feels like it's missing something around there. Big Oil and injectors will fix that though.
Old 09-01-2007, 09:55 PM
im guessin your running a tuner? and exhaust? 32 is actualy prety high for an obs truck not a bad thing tho at around 38 psi you blow head gaskets and at those boost levels your stock turbo gets fried too. you wont see those numbers till you get big injectors
Old 09-01-2007, 10:08 PM
Yeah I'm running a 6 pos chip, 4in exhaust, zoodad mod, rapid flow intake, a banks trans command and soon water meth. injection. My truck is a f250 extended cab, long bed, what are some good quarter mile times for a truck like that with about the same amount of modifications? Rankroddin250 you're from lewiston? Thats awesome, I am currently going to school in Moscow, it is good to hear from someone in good old Idaho!
Old 09-04-2007, 07:54 PM
It's a 7.3L, not a sicko. Tuning plays a huge role.
Old 09-04-2007, 08:45 PM
my truck hits about 34 to 35 and its stock no problems so far but am plannin on gettn a bigger one. but i have bdp stage 2 inj
Old 09-05-2007, 04:13 AM
Send a message via AIM to rufushusky
Yeah i would back it off a little, down to 27 or so...32 your head gaskets should be ok...once you consistently get over 40 psi head studs would not be a bad idea.
Old 09-20-2007, 06:52 AM
32 should be fine
Trying to post that pix.........grrrrr........won't work
http://i232.photobucket.com/albums/e...mage0055-1.jpg
