fresh oil
fresh fuel filter
new water/fuel separater
new injectors
new icp
new value cover gaskets
truck seems a little sluges when cold and idles up and down a little?
How much is a little?
Mine does it too. Combo of worn out HPOP, cold oil, the the #6 injector depleting the oil rail right before the #8 injector fires leaving it without the oil it needs. If you monitored your ICP pressures at idle, you'd see it fluctuate.
Don't worry.
I had a HPOXover hose and it smoothed it out a lot. I'm going to go to a hard line this time (had one crimp fitting crack and one blow) and the Sinister Diesel one looks best to me.
Is there a reason the replacement ICP sensor is different than the stock one I pulled from the engine? I had to use an adjustable wrench to put the new one on...
cps???? ive heard some versions of our cps cause it to fluxuate a little.
Status
Not open for further replies.
You have insufficient privileges to reply here.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
