Banks Transcommand - Ford Powerstroke Diesel Forum
Old 09-01-2007, 02:49 PM
Send a message via AIM to farmboy930
Banks Transcommand
Im looking to help my trans out a little bit and was wondering if any one was running the banks transcommand and if so how it was
Old 09-02-2007, 10:31 AM
I'm running the banks transcommand on my truck and it seems to be pretty nice. The shifts are fast and solid when i have a load on and fast and smooth when I'm cruising around. I hand a bully dog shift kit on my last transmission and it wasnt nearly as good as the trans command.
Old 09-02-2007, 10:39 AM
Desert Shield/Storm Vet
Also I see your going to go with DP tuner. He will be able to program firmer shifts for you if that is what you desire. Otherwise better yet get yourself a valve body and improve your shifts mechanically. Here is a great writeup for you to check out Welcome to guzzle's BTS Valve Body Web Page Just some other options for you to look at
Old 09-02-2007, 09:09 PM
boo!!!!!!!!!!!!!!!!!
Old 09-03-2007, 07:27 AM
why boo??? Cause its a Banks product? They seemingly work great for many people. Not everyone is fortunate like you to have a beast of a machine that can destroy transmissions in a heartbeat
Old 09-03-2007, 07:37 AM
The dp would be better because he can do everything custom. Sure the banks is good but it is designed for everything where as the dp can be custom, for your truck.
Old 09-03-2007, 07:50 AM
understood. To be honest my TS chip doesnt shift as crisply as the Diablo Programmer did....now I have added the Sonnax kit and solved it mechanically.
Old 09-03-2007, 08:03 AM
Yep, A valve body is the best way to get the shifts you want, along with good tuning.
Old 09-05-2007, 07:09 PM
I'm running a Transcommand on my 2000 F250 and it's not bad. Shifts are good and firm but not overly firm. Just installed a TS 6 position and need to take the transcommand out I think because the shifts are so much harder now. If there is anyone out there that know the color of the 3 wires that were in the factory pin locations I would appreciate the info.
Old 10-12-2007, 09:01 AM
I HAVE A 96 WITH THE TS 6 POS CHIP AND I WANT TO KNOW IF THE TRANS COMMAND WILL WORK TOGETHER WITH MY CHIP? MY CHIP DIDNT MAKE A DIFF ON THE WAY IT SHIFTS
