EBPV????? - Ford Powerstroke Diesel Forum
Old 08-31-2007, 06:03 PM
EBPV?????
I disconnected the EBPV wire terminal with the metal clip under the turbo but it still feels and sounds like the EBPV valve is opening for the first 5 minutes of running in the morning. Has anyone had this happen after unplugging the wire? It is not even cold here in south Florida.
Old 08-31-2007, 06:04 PM
Desert Shield/Storm Vet
Actually that is supposed to stop it from closing.
Old 08-31-2007, 06:09 PM
So does that mean it is closing when its cold even though its not connected?
Old 08-31-2007, 06:13 PM
Oh sorry about that Its probobly stuck partially closed all the time like mine was. You should be able to reach under the turbo and unhook the the ebpv from the actuating rod and open it hopefully. I will get you a pic here shortly to better explain it for you. If that doesn't work the only other option I can think of is you will have to remove the turbo to get at it.
Old 08-31-2007, 06:17 PM
I guess my next question should be does the hissing sound go away after 5 minutes? Has this done it more then once after unplugging?
Old 08-31-2007, 06:22 PM
Here is a pic of the turbo pedestal. On the back left is the actuating rod for the ebpv. There is a piston inside the pedestal that is moved my engine oil. If you look there is a sliding clip just unhook and you should be able to physically move the valve open.
Old 08-31-2007, 06:29 PM
Thanks for the picture, it is much easier to see it on the bench than in the truck. Do you know if the rod pushes the valve open or pushes it closed?
Old 08-31-2007, 06:31 PM
Both. It will actuate it closed when its cold out to put a load on the engine to aid in warmup and supposed to open when engine oil temps are up to operating temp.
Old 08-31-2007, 06:40 PM
Thanks for all the help, I will have to get in there this weekend and see whats happening. I guess an EBPV DELETE will be in the works.
Old 08-31-2007, 06:45 PM
You bet Let us know how it goes
