turbo boost bypass?
i got this map fooler/bypass thing and i have no clue where it goes. it is supposed to stop the moter from defueling when the turbo hits its max boost, and this connects between a hose i believe to stop it from defueling.
Do you know where the map sensor is? I don't have a good picture to help, but if you look at your y-pipe you will have a rubber hose probobly 1/4 or 3/8ths running toward the passenger side to a sensor with and electrical plug. You will tie it inbetween the sensor and the y-pipe. I will see if I can find a pic. What brand is your map fooler?
Here check out this link http://www.itpdiesel.com/other/Overb...structions.pdf
