Wastegate - Ford Powerstroke Diesel Forum
Old 08-27-2007, 08:11 PM
Wastegate
has any one seen, or will unplugging the red line on the wastgate cause or create any problems?
Old 08-27-2007, 08:28 PM
ive had mine unplugged this whole year.. turbo spools up faster and gets higher boost....i say go for it
-Raul
Old 08-27-2007, 08:42 PM
Member/MARINE
Send a message via Yahoo to rajharley
yep...the problem that I have with mine now is directly related to unplugging the red line on the wastegate. I cannot keep my damm foot outta the go peddle. You'll love how much faster it spools the turbo.
Old 08-28-2007, 04:57 AM
thanks guys i'm going to unplug it this morning and see how she feels
Old 08-28-2007, 05:07 AM
duct tape & zip ties
Just remember you have to put that redline on a bolt or plug it some how. I stuck it on a the boot clamp coming off the turbo. Works pretty good right there.
I have been running that way for about a year now with no problems. Although you may need to invest into a map fooler. As the map sensor may send an overboost signal to the pcm which will cause the cel to come on. If that happens just clear the code and get a map fooler.
Also you should be running gauges when you do this.
Old 08-28-2007, 03:01 PM
thanks guys, i am running gauges. and i deffinetly noticed a diffrence. alot faster spool up time and +2 psi i can now reach 20psi.
Old 08-28-2007, 03:11 PM
YEAH BUDDY!
IS THAT RIGHT? I was wondering about that myself
All I have to do is unplug the red hose and plug it? What makes it spool up faster?
Old 09-08-2007, 03:50 PM
what does the red line do???
Old 09-08-2007, 03:53 PM
can i do this for a 6.0?
Old 09-08-2007, 03:57 PM
Desert Shield/Storm Vet
The red line is a pressure line to that opens the wastegate. If you remove the line it will keep the wastegate closed longer and build boost faster. I don't think the 6.0's have a wastegate do they?
