Banks 7.3 Turbo Impeller - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-17-2011, 07:44 PM Thread Starter
Im new to this site. I recently purchased a 2000 Excursion with a 7.3. I am looking for a little more power and better fuel mileage. Has anyone installed this before? How did it perform? Thanks in advance.
FordFanEX is offline
post #2 of 8 Old 10-17-2011, 08:15 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Banks Power | 99-03 Ford - 7.3L Power Stroke>>High-Boost Compressor Wheel
This?
It's a wicked wheel? Or the compressor wheel off an early 99 super duty.
If you have turbo surge, it might cure it. Not power gains. For mileage and power,
get a better intake, DIY intake is popular, Zoodad mod, gauges to protect your motor, free flowing exhaust (no catalytic or hollowed convertor, no or straight through muffler), and custom tunes.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 8 Old 10-17-2011, 08:28 PM
usnavyad's Avatar
Feedback Score: 3 reviews
Honeslty i would not trust banks anything
04 harley davidson f-250 arp headstuds oem gaskets,sb intake,edge cts egt probe,sct sf3 idp tuned/ php tuned,blue spring,zerex coolant swap,mbrp 5 inch xdp 6 inch tip,sinister egr cooler,new oem oil cooler,atlas 40 ficm,Painted cac tubes 7.3l wire loom,Diesel site coolant filter
GPDA's other shawn
usnavyad is offline
post #4 of 8 Old 10-17-2011, 08:30 PM Thread Starter
I was looking at the "wicked wheel" but it looks very similar.
post #5 of 8 Old 10-17-2011, 08:33 PM
jesilvas's Avatar
Quoted: 2 Post(s)
It is the same thing. The turbo will try to surge or chatter under load around 1700-2100 RPMs and you will see the gauge flutter. This wheel can help it. You might actually lose a pound or two of boost but no big deal. It will also whistle much better than stock.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 8 Old 10-17-2011, 08:37 PM Thread Starter
Ive read its supposed to spool faster at lower RPM's to decrease the lag. Is it worth it?
post #7 of 8 Old 10-17-2011, 08:43 PM
billelf123's Avatar
Good cheap fix for stock turbo, Banks Wheel, Borg Warner, Wicked Wheel, Superior Wheel (all the same as far as I can tell). I have one and it works fine. My signature lists all my mods and my truck runs plenty strong. If you're going to do more than mild mods I would recommend upgrading your turbo to something like a Garrett GTP38.
Bill
2003
F250 Superduty XLT:
7.3L Powerstroke
TS Performance 6 Position Flip Chip
Eighteen K Power Module
DFUSER MAP-Maximizer
Turbo Master Wastegate Controller
Borg Warner Compressor Wheel
FASS Fuel Pump
FASS Suction Tube
GDS FUEL PRESSURE SPRING
AIH Delete W/Boost Fitting
Sonnax Shift Kit
DIY Big Air Filter
4" Magnaflow Turbo Back SS Exhaust
AutoMeter Ultra-Lite Gauges
6" Suspension Lift
35" Tires
45 Auto
billelf123 is offline
post #8 of 8 Old 10-17-2011, 08:44 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
I think its worth it, then again I was getting horrible surge. No perf gains....which i wasnt hoping for...When I make money by depending on this truck to pull heavy heavy loads, i had to remedy the surge
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
