Anyone have a link or idea how to build a boost leak tester for up-pipes?
If not I might go ahead and just take them off and put the chevy 350 gaskets on there and be done with it, since there is no way I can offord the bellowed up-pipes of an e99 right now.
Boost leak tester for up pipes? Never heard of that, but if you crawl under your truck with a flash light and see soot on the pipes you have a leak. If your thinking you have a boost leak then get a pvc endcap and a compressor hose fitting and pump about 10 psi into your intake then listen for the leaks. Have to have your ccv blocked off or rerouted to work.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
