Sonnax Shift Enhancer = $45 Well Spent! - Ford Powerstroke Diesel Forum
Old 08-23-2007, 09:26 PM
I bought a Sonnax shift kit from DFuser.com and installed it today. Its a simple install requiring 8mm and 10mm sockets, and thin needle nose pliers. Install took about 1.25 hours including the time to drain, and refill the transmission. After doing it once, it can be done in about 30 minutes. It really firmed up the shifts. It doesnt slam, it simply shifts into gear more firmly, and instead of feeling like it kinda drops after it shifts, you feel a push from behind as the power is transferred into the next gear. A great $45 shipped, and 20 dollars in ATF! If anyone has questions feel free to post so I can help you.
Old 02-18-2008, 03:42 PM
i have the same kit for my 99 but i have yet to install it, there was not much in the way of instructions is it really simple and i dont need any, or did you get some instructions for it somewhere?
Old 02-18-2008, 04:30 PM
You can get the instructions off of his website. Very easy to install. PM me and I'll tell you how.
Old 02-18-2008, 04:38 PM
i found it thanks, my truck has 125k on it with boost fooler, unhooked wastegate, and superchips programmer, will it cause damage because of the miles?
Old 02-18-2008, 05:17 PM
its only gonna help your trans, better shifting=happier trans
Old 02-18-2008, 06:40 PM
where do you get these kits
Old 02-18-2008, 06:51 PM
The shift kit will also increase line pressure to help keep the clutches from sliping I did the John Wood valve body what a big deff that made shifts alot better now and doesnt take 10 years to get to the next gear as it did before in a higher tune
Old 02-19-2008, 05:49 AM
what all does this kit do? i have never heard of it before?
