Turbo Upgrades?
So I've read a lot about how to defeat the sweet surge/flutter and some of it contradicts itself. So I just want to make things clear.
From what I've read the cheapest way is a wicked wheel but it doesn't work all the time? And it takes a good 4-5 hours to install, can you do this without removing the turbo? And the easiest way is the ATS compressor housing but it has a 4" inlet. What intakes have a 4" outlet? What are the pros and cons on installing just the WW, ATS and of course just going a little crazy and installing both? Thanks! |
Just pull the turbo, by the time you have the down pipe off, intake off and everything moved out of the way its two bolts and one more clamp... Then you can set it on a bench. ATS housing comes with a intake tube that runs from the turbo to the 4" connector at the CCV...
With pulling the compressor wheel, all the instructions say don't use an impact. Is there a reason for this? Will it screw anything up if I decide to use an impact? Thanks!
Using an impact wrench can strip out the treads on the shaft. This is what you do:
If you have some miles on the truck, you might as well rebuild the turbo while your in there. A rebuild kit is like $80. So, $400-ish for the ATS compressor housing and $80-ish for the WW...and your almost guarnateed no surge. Now....I went with just a WW and a 1.0A/R exhaust housing and I not had surge once since I did the work back in April. It took me about 8 hours total, 4 hours the first day and 4 the next. (I needed a 12 sided 8mm box-end to get the compressor housing off.) |
I have heard that you can buy the ATS compressor housing without the tube that connects to the ccv, so my advice is to buy one from a reputable vendor that includes the 4inch tube if you choose to go that route. You can find em for around 400 bucks. Quite a bit more than a wicked wheel, but you don't have to take the turbo off to install the housing.
I dont see how an impact could strip the threads if you are taking the wheel off... Obviously I would not run it back on with a gun haha and how hard is it to rebuild the turbo? And other than the 12 point 8mm socket, are there any other special tools that I will need?
The threads are really fine so be careful. Probobly the biggest reason they dont want you to use an impact is if you don't have it in reverse you going to do some damage. The turbo is really easy to rebuild. You will see once you get the turbo apart trust me
It took me about 2 hours total to rebuild mine...that's with cleaning it too. It was my first one. Make sure you get a rebuild kit and make sure it has new seals and all. Also...goto the dealer and get new upper and lower pedistal o-rings. (They are like $12) Once you get the turbo apart, you'll see how it all goes back together. It's really easy.
Sorry, but I'm gonna hijack this for a minute. Ditty, when you went to the 1.0 exh housing, how did it affect the spool time? Was it noticeably slower? I'm thinking about going to a 1.0.
