Aftermarket Intercoolers - Ford Powerstroke Diesel Forum
Old 08-21-2007, 10:16 PM
First off, are they worth it? Second, what will they actually do for you?
Old 08-21-2007, 10:25 PM
they will drop your EGT's so yes they are worth it but not until your making big power or if EGT's is an issue.... since you got a 7.3L i would just suggest to upgrade to the 6.0 IC for like 250 bucks.. its a lil bigger than the stock 7.3L
you can usually find them on ebay
-Raul
Old 08-21-2007, 10:42 PM
PIPE HITTER
-Raul
yep, the 6.0 is about 33% larger overall and will fit right in.
Old 08-22-2007, 05:47 AM
You will see very little drop in EGT's with the 6.0 IC. About 50-75 loaded and nothing empty... Altho bigger, it still has the same bottle necks the factory IC has.
The biggest IC out right now is the sperco 6.0, thats what I will be getting when I have the cash.
Old 08-22-2007, 01:53 PM
hypermax tapercore is probably the biggest, but its also the most expensive.
