GAUGES! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-14-2007, 08:13 PM Thread Starter
tonypagnano's Avatar
Send a message via AIM to tonypagnano
GAUGES!
hello, i was wondering what i should expect my EGTs to be and my trans temp and boost to be while running a 00 powerstroke automatic single cab with 4 inch turboback exhaust, intake, dp tuner with boost fooler. also, at what readings would it be wise to back off and let the truck cool down and get back to normal.
tonypagnano is offline
post #2 of 6 Old 08-14-2007, 08:25 PM
If the thermocoupler is pre-turbo try not to exceed 1250F. I think you should run about 650 to 800 on the pyro cruising down the road.
2005F250 is offline
post #3 of 6 Old 08-15-2007, 09:30 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Also trans temps will probobly read or should read 60-80 degrees over outside ambient temps without a load ie not pulling anything.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #4 of 6 Old 08-15-2007, 10:46 AM
Send a message via AIM to jeremy2146 Send a message via MSN to jeremy2146
I just got my 97 F350 7.3L, and was wondering what brand is a good set of gauges, I was looking into isspro, but can't make up my mind. Any advice?
Also is there anywhere that I can get the A-pillar gauge pod in Ford tan, or do I really have to paint it?
jeremy2146 is offline
post #5 of 6 Old 08-15-2007, 12:57 PM
vitalidle's Avatar
I have isspro's and like them. Lots of members have autometers and like them, so either or look for the best price of the two. Yes the piller pod only comes black as far as I know.
Auto 93,000 miles
DP Tuner F5
post #6 of 6 Old 08-15-2007, 01:07 PM
CSIPSD's Avatar
Isspro... Got 16 of them... and 4 autometer's in the tool box...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
