help on the evo 2 install please - Ford Powerstroke Diesel Forum
Old 08-08-2007, 07:06 PM
just got the egt cable done on the evo 2 and wondering where does it plug into......no room for it on the evo monitor, I'm assuming somewhere into the computer?? any help thanks..
CP
Old 08-08-2007, 07:12 PM
Send a message via AIM to Tim99ws6
If it's anything like the juice w/ attitude i just hooked up on a cummins, the EGT cable goes to the central control box for the evo, and then the monitor is ran from a seperate cable coming out of the box(a gray wire)
I believe it was a yellow and red wire you have to connect to the box.
Old 08-09-2007, 01:37 AM
Send a message via Yahoo to pullmaxdude
Your EGT cable hooks in at the OBII conector, should be on the RH side of the EDGE connector that you are plugging in to run the monitor...
Old 08-09-2007, 06:04 AM
I saw the plug hole on the monitor to hook up to the computer for updates...is it on the plug that goes into the truck computer down by your feet??
Old 08-09-2007, 07:03 AM
Yes it is on the right hand side of the plug by your foot
Old 08-09-2007, 09:52 AM
thanks, I will look there tonight and hopefully get her hooked up, once again, what a great site
Old 08-09-2007, 06:52 PM
where to snake the egt through
Where do you put the egt wire through to the inside of the cab......is there a hole somewhere someone uses? my firewall looks sealed up
Old 08-10-2007, 01:43 AM
Up and to the left of the brake pedal, mine has a foam block with a cut out that I ran through. I will try to get some pics tonight when I get home
