need some help plz - Ford Powerstroke Diesel Forum
Old 08-08-2007, 03:57 PM
need some help plz
where is the pcm code located at?
Old 08-08-2007, 04:00 PM
just in front of and basically next to the park brake pedal. You have a 10 MM nut you access from the engine compartment..then the bolts for the PCM are on the inside. It is silver and has a black plastic cover around it
Old 08-08-2007, 04:13 PM
so the 10mm is under hte hood ? and the 2 little ones that hold the black plastic peace you take off to?
Old 08-08-2007, 04:14 PM
yes....the 10mm one is under the hood on the thin, tall electrical connector....then there are a couple 7mm ones under the dash for the plastic cover and a couple 8 or 10mm (cant remember) ones for the PCM itself...
Old 08-08-2007, 04:27 PM
when you take hte 10mm out, does it unplug? and hten go under the dash and pull on the plastic peice and it will come out? or do you gota yank on it a bit?
Old 08-08-2007, 05:13 PM
The Fat Mod
For just the code, you should beable to just take the cover off on the inside. Atleast I was able to. There was a small plug over a hole on the end of your PCM that has a sticker on it. Has a few numbers and letters, and that is your PCM code.
On mine, I did not have to go through and take out the PCM just for a chip. Maybe different on other trucks though. Mine was a 2000 6 spd.
Old 08-08-2007, 08:48 PM
You have a NVK computer code...
But I would get the PMT programs if I were you...
