$799 for the bracket and hardware. Compressor is $415.
Welcome to our Website : Extreme Outback
Bolt-on aire Mounting Bracket
$799.95
As seen in the April 2007 issue of "DIESEL POWER" Magazine on page 30!
Mounting kits to fit the Cummins, Duramax and Power Stroke, V-8 & V-10 gas motors. Mounting kit includes all cast aluminum brackets, mounting plates, idlers, bushings, serpentine belt, nuts, bolts and washers. This is not just a "bracket" and your on your own type kit. This is a very comprehensive mounting system that makes the install look like OEM. The mounting kit may seem pricey, but find a fabricator and figure about 12 -15 hours of his time not including parts and you'll see what a bargin it really is.
Please call to discuss your particular install application!
As seen in the April 2007 issue of "FOUR WHEELER" Magazine on page 29!
Mounting kit price does not include ExtremeFlow compressor.
ExtremeFlow Belt Drive Compressor SERPENTINE BELT
$414.95
This compressor puts out a whopping 8 CFM at 100psi. Capable of 200psi, the unit has a greasable zerk fitting for lubrication and uses high temperature synthetic grease. ExtremeFlow compressors will fill tires, run air tools and can be used whenever large volume of air is needed. Each unit is manufactured with the highest quality components for the ultimate in performance. The compact size makes for easy installation. Dimensions are 5.5" in diameter, 8.5" long with eight mounting ears. This is the ultimate compressor for speed, volume and performance.
