5" exhaust tips - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-04-2007, 10:11 AM Thread Starter
01psdually's Avatar
Question 5" exhaust tips
I am ordering an exhaust kit from FBD next week and was wondering if anyone knows were to purchase weld on 5" chrome tips. I had one on my '99 dually that went from just behind the rear axle and bent out behind the wheel so you could not see anything but the 5" chrome pipe from behind the truck. I have been checking online vendors but have not been able to find anything but the short bolt on tips???
01 F350 CREWCAB DUALLY
ZOODAD MOD
FOIL DELETE
CCV MOD
FBD 4" TURBO BACK STRAIGHT PIPE :burnout
EBPV UNPLUGGED
01psdually is offline
post #2 of 9 Old 08-04-2007, 10:26 AM
I bought one from jegs in columbus ohio that sounds like what you're looking for. I think it was a bully dog. It was 4" in, 5" out and about 24-26" long with about a 45 degree bend in the middle. I'm sure one of the vendors on here carry the same thing. I bought mine before I found this website and all of the help and good deals on here.
screamin7.3 is offline
post #3 of 9 Old 08-04-2007, 10:48 AM Thread Starter
01psdually's Avatar
Thanks for the reply, that sounds exactly like what I had. I am sure someone will come along that knows if one of the forum vendors carry that style tip.
ZOODAD MOD
FOIL DELETE
CCV MOD
EBPV UNPLUGGED
post #4 of 9 Old 08-04-2007, 10:49 AM
WD40's Avatar
Quoted: 40 Post(s)
Go ahead and put a 6 in tip on it, they
look real cool and the sound is great.
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #5 of 9 Old 08-04-2007, 12:59 PM
You can 't go wrong buying exhaust from FBD either, I put a 5" turbo back with no muffler on my '00 F350 two weeks ago, and a 4" turbo back no muffler on my pals '01 last night. It's almost too easy.
post #6 of 9 Old 08-04-2007, 01:23 PM Thread Starter
01psdually's Avatar
Good to hear that, I have heard all good things about the FBD kits and that the installation is relatively simple. Thanks for the info.
ZOODAD MOD
FOIL DELETE
CCV MOD
EBPV UNPLUGGED
post #7 of 9 Old 08-05-2007, 06:59 AM
Looking at your mods list, looks like you're going to need more after you get that exhaust on there. I just took out my superchips 50 hp chip (been in there 7 years) and the edge ez. Replaced chip with a 3 position chip from dp tuner. It has a switch that's about the same size as the remote doorlock controller that goes on your keychain. I had mine programmed with the stock setting as well as 40 hp tow and what they call the 80 hp econo tune. This thing flat out gets it. My truck is a six speed, and the chip (even in the 40 setting) made it so responsive it blew my mind. I cant hardly shift it quick enough. If you ever decide you want a chip, this is the way to go. For just over 300$, I got the chip and the F5 controller switch. The really cool thing about it is if you call down there, or up there in your case, (I'm from southern Ohio) you're talking to the owner of the company as well as the one that will be burning your chip. I was really impressed all the way around. Excellent service, reasonable pricing and a product that delivers high performance without excessive smoke and egts. Sorry for the rambling, but along with Gus at FBD, Jody at Dp tuner is a real class act. I'll take these guys any day over some of the other outfits out there. (Some of the outfits in the diesel magazines don't give a flip if they help you or not) Just my 2 cents worth, might not even be worth that much.
post #8 of 9 Old 08-05-2007, 06:04 PM Thread Starter
01psdually's Avatar
Thanks for the chip info. I will give them a call after the exhaust and gauges.
ZOODAD MOD
FOIL DELETE
CCV MOD
EBPV UNPLUGGED
post #9 of 9 Old 08-05-2007, 06:18 PM
International Threat
Marty's Avatar
I'll tell you I'd personally buy a 6" tip or bigger if it was me. In fact, I'm eyeing up this one 7" pipe at at a local big rig shop trying to figure out how to reduce one end down to 4" and it's about 30" long right now.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
