custom tunes - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-30-2007, 04:56 PM Thread Starter
onecrazyblackredenck's Avatar
custom tunes
I am about to get some custom tunes how much do they normally run? also right now I am running the ts 6 pos I am wanting a tune for just smoke I mean I want some insane smoke, better than the 140 setting on the ts. How does it work, is there a list of tunes I can choose from or what ?
03 F250 4wd auto strait pipe quad cab lariat 33x12.50x18
84 K5 blazer CUCV M1008 dana 70 front and rear, detroit lockers front and rear, 45" tractor tires, 6.2 diesel
1978 cj5 built 304 lots and lots of rust
onecrazyblackredenck is offline
post #2 of 9 Old 07-31-2007, 08:40 AM
CSIPSD's Avatar
Who you sending your chip to? Call them and ask what they suggest... Your not going to get much more smoke out of a stock injectored truck then the 140 setting...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 9 Old 08-01-2007, 06:22 PM
yeah i got the "DP" tuner and got the 140 agg and its got a lil a bit more smoke than the t.s. but its close but if ya want smoke get ya some **530*'s there nasty lol but get ya some stage 1 or 2 squirters
***** BDSstroker02*****02 FORD F-250 4X4 BLUE AND GOLD
6 INCH PROCOMP
"37" INCH MUDGRAPS ON "20" INCH PROPS
"DP" TUNER F5
ZOODAD
(BOONDOCK) KUSTOM AIR INTAKE
(BOONDOCK) KUSTOM EXAUST SOON TO BE STOVE PIPES
AUTOMETER COBALT GAUGES ON ORDER
kcreel1 is offline
post #4 of 9 Old 08-02-2007, 05:29 AM Thread Starter
what are 530's?
post #5 of 9 Old 08-02-2007, 07:01 AM
CSIPSD's Avatar
Injectors, there are true 530's which come out of a bigger brother of our motor... or hybrids, which use the 530 internals... both are very large...
Joe
CSIPSD is offline
post #6 of 9 Old 08-02-2007, 07:15 AM Thread Starter
I am asuming when you get bigger injectors its dumping more fuel so inturn you are getting worse mileage ?
post #7 of 9 Old 08-02-2007, 07:21 AM
CSIPSD's Avatar
My milage stayed about the same...
Joe
CSIPSD is offline
post #8 of 9 Old 08-02-2007, 09:38 AM
Slated4greatness's Avatar
Quoted: 3 Post(s)
I can't get a good mileage run on my truck. The **** skinny pedal keeps going to the floor!! If you want smoke come ride in my truck, it's almost embarrassing.. In the 80e I can stop traffic if I don't roll into it..
Stg3's and 140a = night time during the day down low but once it lites it cleans up to a lighter gray...
P.S. You could always to the "Garbage bag over the intake" mod..
2006 Dark Slate F350 CC LB 6X6 Lariat Tow Boss edition, Complete with training wheels.
BPD VK688 Kit, W Pump, EGR, FICM, Decked block & Heads, ARP's, Coolant filter, RR, Aux coolant lines, Train Horns, SCT W/GH tunes, Recon smoked LEDs, Pressure pro TPMS, Firestone air bags, Alpine/Infinity/Polk sound system, CTS Monitor and Autometer analog backups. MPG Max Water injection with custom 17 gallon tank. 4" straight to 6" Aussies.
Slated4greatness is offline
post #9 of 9 Old 08-02-2007, 10:05 AM Thread Starter
bag over the intake??????? what is that? seems like it would be bad on the truck
