what to get for a 7.3 - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-29-2007, 08:44 PM Thread Starter
tonypagnano's Avatar
Send a message via AIM to tonypagnano
im buying a 99 powerstroke (automatic) and i would like to see what you guys recomend i buy for it. Im looking into a DP tuner, AEM brute force intake, and silverline 4" turboback exhaust. im also going to get boost, egt, and trans gauges. i would just like to know if that is a good combination of mods and if not id like to know what i should get instead. i want my truck to be reliable and get decent gas mileage, like better than 14mpg. i also want it to go pretty good and sound pretty good. i cant afford injectors and turbo and mods like that quite yet so im lookingto just get started with intake, chip, and exhaust. also, if anyone knows more about DP tuners i would like to talk to you because i cant really figure out to much about them. Thanks alot.
tonypagnano is offline
post #2 of 14 Old 07-29-2007, 09:00 PM
jfines@cox.net's Avatar
I would go with gauges FIRST. then go from there. The exhaust is the next place I went. Then chip/programmer. Then intake. As I understand it, intake won't do much till high HP.
Jody in Mesa,Az
97' crew cab xlt, F350
7.3L PSD
Long Bed
2 wheel Drive
3 gauge pillar(egt,boost,trannytemp)
3" down pipe
DP Tuner
CAT Delete.
Tranny Rebuid ( 3 disk TQ, extra clutches, all billet steal internal parts, New HD Valve Body, 45,000 BTU cooler)
37' Avion 5th Wheel
jfines@cox.net is offline
post #3 of 14 Old 07-29-2007, 09:19 PM
pojo4223's Avatar
Send a message via AIM to pojo4223
i just bought a 99 psd, first thing i did was straight pipe the exhaust, then an intake, and chip, definitely do it, thats all you need for now to start, if your gona be running it hard i would recommend the gauges for sure, but to start, chip , intake and exhaust is the way to go, im running about 16-17 mpg and still having fun driving it, go for it. . .
pojo4223 is offline
post #4 of 14 Old 07-29-2007, 09:24 PM
The Fat Mod
Logan's Avatar
Sounds like you have a good set up in mind. to the ORG too by the way.
Logan is offline
post #5 of 14 Old 07-29-2007, 09:27 PM
I have an 01 auto 2wd crew cab short bed that has a 4" turbo back exhaust and an intake and I get 19 MPG on the highway... I'd say you're on the right track to getting good mileage and having the power when you want it. Sounds like you have everything pretty much in order!
And welcome to the .org! we are definately glad to have you here!
Blue01F250 is offline
post #6 of 14 Old 07-29-2007, 09:30 PM
Gauges first before tuner.
2001 Excursion
PHP Hydra, Insight CTS, Intake, RR Boots and plenum inserts
345,000 miles and counting!
fulloutpwr is offline
post #7 of 14 Old 07-29-2007, 09:38 PM
Plus, Gauges first gives you a good baseline to refer back too. I spent a couple of months watching my gauges. And I can tell you, that when my chip is on high, I burn hotter when I get in to it. Now with the larger DP and no CAT I can tell you that around town I am running 100 to 200* cooler.(I tow again next week so we'll see) While towing my 5er I could easily hit 1400* in seconds.
Jody in Mesa,Az
7.3L PSD
Long Bed
2 wheel Drive
3" down pipe
DP Tuner
CAT Delete.
37' Avion 5th Wheel
post #8 of 14 Old 07-30-2007, 05:40 PM
onecrazyblackredenck's Avatar
definatly gauges first, youll be surprised how fast your egts rise!
03 F250 4wd auto strait pipe quad cab lariat 33x12.50x18
84 K5 blazer CUCV M1008 dana 70 front and rear, detroit lockers front and rear, 45" tractor tires, 6.2 diesel
1978 cj5 built 304 lots and lots of rust
onecrazyblackredenck is offline
post #9 of 14 Old 07-30-2007, 06:53 PM Thread Starter
Thanks for all you help guys i think im going to order gauges with the rest of the stuff. how hard are the gauges to install? well im sure ill find out. thanks again.
post #10 of 14 Old 07-30-2007, 07:20 PM
Not hard at all... most time consuming of the process is running wires and bitting your nails at drilling into exhaust manifolds and stock trim pieces! I started my install at 11PM and finished at 2AM with a 3 set of gauges.
2001 Excursion
