TS Problems
Anyone had any problems with the TS tuner? I get my check engine every once and a while when it'll come on for like 15-30 minutes. Anyone had anything similar?
May be an overboost condition. You'll need a MAP fooler to keep that from happening.
You most likely are overboosting the engine. The Map Sensor is reading high boost readings and defueling your engine. You can solve the problem with a map fooler. You can make one yourself or you can buy one.
Also get those gauges installed before you play around to much. Because high egts will kill your truck in no time. But to make sure try and pull codes from the truck. |
yeah man mine was doing the same thing,, and was SLAMMING my tanny into 2nd and 3rd,, no rime or risen, i just changed to an Evo 2,, havent had it long enuf to dislike it yet, the display is great though. BUT id luv the HP the TS put out!!!
Over boost or ICP code...
