Turbo - Ford Powerstroke Diesel Forum
Old 01-18-2011, 06:53 PM
Turbo
Hey guys i'm going to be pulling my turbo off here sometime soon. I'm going to be rebuilding the turbo and putting in a non-ebpv pedistal and a high flow outlet.
But what i was wondering if i should upgrade the intake housing with a 4 inch? I want to hear more whistle, so would the stock wheel and housing create some more whistle or do i have to install a wicked wheel to accomplish that. I read that doing both creates and annoying amount of whistle, i don't want that much just a little more so i can hear it when i drive around. I also read that the stock wheel is more efficient?
I wanna be able to do it right the first time. Which is better stock with housing, or do both? I kinda want to do the housing, so when i add a tuner later i won't have to worry about surge ever.
Old 01-19-2011, 09:25 AM
Old 01-19-2011, 10:16 AM
The "upgraded" intake housing you talk about is the ATS ported compressor housing, right at $425 bucks... It is the cure for surge on the stock turbo, but is NOT a performance upgrade.
I repeat, there is NO performance improvement with the ATS housing.
Old 01-19-2011, 11:02 AM
Oh ok, well now knowing that. While I got the turbo off, I probably will put one on so I won't have to worry about surge. But now, should I keep the stock wheel or go with the wicked wheel?
Old 01-19-2011, 11:42 AM
Do one or the other not both, a wicked wheel or a stock wheel with a ported housing
Old 01-19-2011, 02:06 PM
May I ask why not both? I'm just curious
Old 01-19-2011, 02:10 PM
says on the website that using a stock wheel you loose psi. "The ATS Ported Housing offers significant advantages beyond a replacement compressor wheel. The upgraded housing with factory wheel actually flows more air than the "WW" replacements. This Ported Housing will only work on the 1999.5+ 7.3 trucks."
Old 01-19-2011, 04:28 PM
As your doing all this keep in mind you are still pissing money away on a stock turbo... It is what it is.
$200 bucks for a high flow outlet, $200 for the pedistal, $425 for the ATS housing... not to mention the $300-$400 your paying someone to rebuild your stock turbo...
You have $1200 bucks wrapped up into a turbo that still can not make anymore boost then it could before...
Or you can sell it for a few hundred as a core and get a GTP-38R for $1500 or so.
Old 01-19-2011, 05:24 PM
Completly off topic (sorry) but is your truck your daily driver? Your sig has everything...
Old 01-19-2011, 05:31 PM
Yes it is...
3 motors
6 trannys
5-6 turbos
1 rear end
lots of other crap...
Lets just say I have tried alot of crap.
