what mods first - Ford Powerstroke Diesel Forum
post #1 of 12 Old 01-18-2011, 06:20 PM Thread Starter
d and b installer's Avatar
what mods first
Just picked up bone stock 2000 f250 with 7.3 4r100 4x4. 143000 miles other than warn hubs and a wicked wheel what mods would you recommend for fuel milage and maybe a bit of power. This truck is going to be used mostly for commuting. But will spend sometime offroad to get to my favorite fishing hole maybe pulling a couple broken jeeps and chebys every once in a while.
My truck
2003 f250 6.0 , 5r110
, afe stage2 intake, diamond eye 4 inch exhaust dumps in front of passenger tire, arp headstuds, Swamps 58V FICM
, SCT Tuner canned tunes for now, welded egr cooler, Bodywork by trailer in the ditch.
made new by Tech Auto Body
, Blue Ox goose neck hitch
. gone the bank said I couldn't keep her R.I.P.
d and b installer is offline
post #2 of 12 Old 01-18-2011, 08:10 PM
nielsencc86's Avatar
Start with the basics and go from there. A good DIY intake(Cheap) or afe, banks, etc-anywhere from $50-350, a good free flowing exhaust-around $4-500 installed, custom chip-around $200-500 if you can find used it would be cheaper, A regulated return fuel system is an awesome upgrade and one of the first mods I think you should do(Something Ford should have done from the factory)-around $350-600 if you make your own or buy a kit, a hpx cross over to smooth out the oil flow-about$50 bucks. I think this is a good stage 1 setup that makes these powerstrokes very competitive on the street with a lot of reliability included. I would say for you that would be a great starting point but I believe you will be bitten by the power bug. Anything above that and you will want to focus on transmission upgrades along the lines of torque converter and valve body upgrades. Then you should upgrade your high pressure oil pump to support the injectors you will want to get. A 38r would be a great turbo upgrade if you think you will stop right about here. This is stage 2 to me and I think this is where it starts to get pretty spendy. After this the limit is how much money you have in your wallet. Good luck and enjoy the truck!
Late 99 SC LB PHP 6 stage Chip, gillett injectors, afe intake, 5" straight pipe, BTS trans, gauges, 4.5 " lift 38x15.50R20 Toyo OC MT's, 05 Headlights, Appearance mods
nielsencc86 is offline
post #3 of 12 Old 01-18-2011, 09:58 PM Thread Starter
any recommendations on a company to get teh chip thru. Im going wiht the sct for my 6.0 truck but havent dealt to much with the 7.3s.
My truck
post #4 of 12 Old 01-19-2011, 03:01 AM
If your gona be throwing many go fast parts at the engine you may want to address the tranny with a valve body and possibly a torque converter. As far as chips go its a toss up, wildman, DP, PHP, beans, etc. take your pick.
Jim
2000 7.3l 4x4 6sp
DIY intake
4" exhaust
6pos by Dyno Proven
Wicked wheel
160cc
Honey Badger jr
custom clutch
Auto Meter Z series gauges
jimmyp is offline
post #5 of 12 Old 01-19-2011, 07:25 AM
maddogv21's Avatar
If you are gonna put ANY more power it, get you a set of gauges first! Trans temp boost and Pyro....
2000 F-250 XLT Crew cab 4x4
DIY air intake
Straight exhaust to 5" mitre stacks
Stancor GPR
Tru-Cool Max trans cooler
Phantom II Boost, trans temp and Pyro gauges
Zoodad
Foil delete
2005 grille conversion
Warn manual lockouts
Warn trans4mer grill guard
maddogv21 is offline
post #6 of 12 Old 01-19-2011, 09:02 AM
DSTRBD's Avatar
I would start with an exhaust and intake to get the air flowing for better efficiency.
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #7 of 12 Old 01-19-2011, 09:59 AM
Good suggestions....
If it were me, and knowing what limited info I have learned from here already,,, I would also do a couple other small but yet very helpful down-the-road things once you do get started.
first--- Have you noticed any small oil leaks ? ? is the valley of the motor dry or have diesel/oil in there? ----this will make sense later..
As already mentioned Air In / Air Out very helpful. Good filter as DIY 6637 and a 4inch exhaust will enhance anything else you do down the road.
But if it were me, while setting on top of the motor doing some of the mods mentioned above,,, I would attack some of the inherient leaks your truck either HAS or GONNA HAVE! These friggin trucks have 9742 orings in em' that are going to leak at one time or another! ( not really that many),,,
Fuel drain orings on the bowel and ped o rings come to mind first. I'd also replace the IC boots while up there too. Easy to do if you are addressing things such as Wicked Wheel replacement, oil X-over line, foil delete,etc,.
There's nothing more frustrating to me than to have just finished an install of some gizmo on yer motor and yer all happy and glad it's over,,,, only to find out the next time you pop the hood to Gawk at your new doodads,,, you see a friggin' oil leak right underneath that nice pretty, expensive gizmo you installed last week...... been there too many times like that on my truck already......
RB
XR-2001 is offline
post #8 of 12 Old 01-19-2011, 12:54 PM Thread Starter
been looking for more info on the foil delete what is it how does it help. the only mention i ever see of it is someone saying theyve done it. Not really looking for much power gain just mpg the 6.0 truck is going to be the fast one the 7.3 is for getting to the fishing spots and towing the 6.0 when it breaks. Of course it's also a commuter truck close to 30000 miles a year. if i can pull 20 miles to the gallon cruising at 75 then i dont have to feel stupid for getting rid of my towncar.
My truck
post #9 of 12 Old 01-19-2011, 05:35 PM
maddogv21's Avatar
The foil delete does nothing but make more noise....there is NO performance gain what so ever!
DIY air intake
Stancor GPR
Zoodad
Foil delete
post #10 of 12 Old 01-20-2011, 04:41 AM
agreed
I was not intending anyone to believe the delete was a gain ,,, simply a mod a lot of guys do when they get started on moddin'.
RB
XR-2001 is offline
