Exhaust housing question - Ford Powerstroke Diesel Forum
Old 01-18-2011, 06:07 PM
I was looking at a exhaust housing out of a van turbo that is a 1.15 housing. I currently have stage 1's and PHP tunning. I am not experiencing surge at this point in time, but I hear that is luck of the draw. So my question is will this housing cure surge or do I need a ww? Would I need to get my chip retuned if I did I got this housing? What real gains could I see from doing this? I tried searching and read threads for over an hour and couldn't really find answers so I appreciate the insight.
Old 01-18-2011, 06:23 PM
Let's go B's!!!!
Feedback Score: 5 reviews
The 1.15 exhaust housing will not do anything to cure surge. The ported compressor housing is what will cure surge. The bigger exhaust housing will keep EGT's down and your turbo spool a little slower. The ported compressor housing allows air to escape back through the intake to prevent the turbo shaft from stalling/surging. Some say the WW helps some say it doesn't. If you're not getting any surge right now, I would leave it alone.
Old 01-18-2011, 06:31 PM
That's the information I was looking for. Thank you very much.
Old 01-19-2011, 05:15 PM
Let's go B's!!!!
Old 02-27-2011, 07:48 AM
1.15 housing will help cure surge. It will change the efficiency map from stock. Any surge would occur at a different load/rpm. Just my 2 cents.
