gtp38r questions... - Ford Powerstroke Diesel Forum
post #1 of 25 Old 01-18-2011, 11:12 AM Thread Starter
rt_hawk's Avatar
gtp38r questions...
So I am going to buy a gtp38r in a couple of weeks here and I have a few questions.
1) Am I going to notice any more power with the stock injectors? I have a dp-tuner, intake, exhaust and I will be doing some stage 2's in the near future. Anyone dyno their truck before and after with stock injectors?
2) The turbo says it comes with a high flow 1.0 turbine housing, is this ebpv free and will I be able to just hook my downpipe right back up? Or do I need to swap the housing from my stocker? Im getting the turbo from riffraff...
3) I want to gut my pedestal, can this be done with the pedestal still in the truck with the turbo removed? Is there room to just take off the snap ring and pull the internals out then put a freeze plug in back and tap and plug the front?
Thanks in advance for the help guys!
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #2 of 25 Old 01-18-2011, 05:12 PM
there is no ebpv in the 38r and no you dont have to switch housings. with the turbo off just take out the 4 bolts holding down the pedestal and gut it on the workbench. it will be good to change out the o rings anyway. i dont know if the 38r necessarily gives you more ponies but it will pull harder in the upper rpms with the larger exhaust housing. its an ok turbo, i used to run one but now run an h2e on stock sticks. my birthday is next month and sticks are going to be my present.....
indyF-350psd is offline
post #3 of 25 Old 01-18-2011, 06:13 PM
i picked up a non ebv pedistal and a high flow outlet when i did mine for like 150 more dollars and now i never have to worry about the pedistal leakin. the thing you'll notice the most is the noise. they are loud!!!
bruce51d is offline
post #4 of 25 Old 01-19-2011, 06:11 PM Thread Starter
rt_hawk's Avatar
Thanks guys, I think I'll just throw a non-ebpv pedestal on then.
rt_hawk is offline
post #5 of 25 Old 01-19-2011, 06:34 PM
aawlberninF350's Avatar
Do you need to get new tunes from Jody when changing from stocker to 38r?
02 F350 Lariat 4X4 CCSB SRW 4R100 w/FTVB.Mishimoto 6.0 IC.26 row 6.0 trans cooler.6637.WW.RiffRaff FrxGen2/Plenum inserts/AIH delete/boots.Hutch.Harpoon.50 cent.Isspro EVs.Walker BTM.DP Tuner.AC mod.Mile Marker 449ss.Fumoto.DDM HID 55w 4500k.Bilsteins.Dieselsite Coolant Filter.
Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats. - HL Mencken
aawlberninF350 is offline
post #6 of 25 Old 01-19-2011, 06:53 PM Thread Starter
rt_hawk's Avatar
Nope, you do not.
rt_hawk is offline
post #7 of 25 Old 01-19-2011, 07:10 PM
no you dont have to get new tunes from jody but i'd suggest gettin new tunes from beans. had both, satisfied now
bruce51d is offline
post #8 of 25 Old 01-20-2011, 10:38 AM Thread Starter
rt_hawk's Avatar
Hey bruce51d, did the bolts to attach the high flow non-ebpv housing to the turbo come with the housing or turbo? If they don't do you recall what size they are? Thanks again.
rt_hawk is offline
post #9 of 25 Old 01-20-2011, 10:52 AM
Naw you reuse the stock bolts. 10mm 12 point iirc
bruce51d is offline
post #10 of 25 Old 01-20-2011, 10:54 AM
STANGMAN893's Avatar
Hardware and o-rings is included.I love my 38r.Best mod I've done and enjoy it everyday.
It is definitely louder sounds like being on a plane ride and I'm running a superchips 1705 tuner and now have a boost fooler to add too.Good luck and enjoy it.
STANGMAN893 is offline
