oil pressure gauge
i have bought glowshift oil pressure gauge and oil temp gauge. Just want to know the best place to plug them. thank
![]() ![]() These pics are ones that CSIPSD sent me when I asked him the same question. There is also a block plug on the driverside close to the back of the block where you can tap into for oil pressure if you don't want to put the sender in the HPOP res. The sender by the filter is for oil temp. |
good, thank for the info, so i unscrew the torx bolt on the top of the pump and put the sender there. and how many psi should i get there. thank
will it be 40-70psi or i will get the hi pressure like 4000?
It'll be the lower oil pressure.
For HPOP pressure, the gauge gets the reading from the ICP sensor.
