AIS Severe Duty Air fillter kit
A farmer that lives near me that has two 7.3 PSD highly recommended that i upgrade my 99 F-250 factory air cleaner and box up to this kit to help fight the dirt that goes along with farming. He says that the trucks seam to run better and that the filter does a lot better job of catching dirt that the factory filter. But before i go out and spend the $200 that it cost to get one of these i thought i would as on here. My truck will be a farm truck pulling hay and driving in fields so dirt control could be a problem. Here is a link to what i'm look at. Motorcraft FA-1759 Ford 7.3 Power Stroke AIS Severe Duty Air Filter Kit
DIY
i wouldnt worry much about it. i think the 6637 diy intake with a custom filter cover can keep out enough anything. you would be amazed and what ford puts through your turbo from the factory. i use mine hard. just make sure you use a good brand paper air filter thats waterproof. super easy, cool turbo whistle, sharp looking custom covers, CHEAP. google 6637 air filter mod or cover it all pops right up. you can also search this forum using the search tab above, its very popular.
I went from factory to a 6637 and then dumped it in the trash in favor of the Ford AIS system. The 6637 is popular because it is cheap and filters well. It has more than one major drawback. The first one is noise! That thing is freaking loud which is fine for awhile but when you actually work the engine like when making long heavy tows it gets very annoying. The other drawback is that it just lays there in the engine compartment exposed to abrasion and water.
The Ford AIS system looks factory and has excellent filtration, flow, and is as quiet as stock. |
I'm getting ready to buy one as well. Edit: Just ordered it. Last edited by Mack; 02-22-2011 at 08:33 PM. |
I just installed mine today. Very easy install, looks great, and truck does seem to run better and have a little more power. Imo you can hear the turbo spool up a little faster, and it IS a little louder than stock, but not much. Very happy with it so far! And i did the Zoodad mod while i was at it
Mine should be here Sat. and will probably do the zoodad mod as well. Looking forward to it.
I was told by a good friend at the local ford dealership(CEO) that the only reason they didn't put these in to begin with, is the people who take it to the dealer every time the "service engine" light comes on in the middle of Chicago didn't need a filter like that, so Ford's saving money...
It DOES have better air flow and filtration than stock, but filters are expensive if you don't clean them regularly. By that, I mean the stock filters are meant to be used then disposed, they're cheap, I blow my AIS filter out with air compressor from the top, then use a vac on the bottom at least once a month and it still looks brand new. If you use it on terribly dusty (like super fine clay, finer than sand) roads you'll dump so much dirt out of that filter you think you emptied a bucket... Don't forget to do the Zoodad mod while your in there, I gained ~2mpg between the two! |
the AIS is a great intake. i had it on my other truck and its an awesome filtering intake. the stock airboxes are kinda crappy and sometimes dont "mesh back together" when you put it back together. the AIS air filter is pretty big and almost looks like a hepa filter. either intake is a good option...you could always try the DIY tymar intake as its cheap and if you hate it order the AIS.
I've been researching/reading all morning about the AIS and finally decided to go with that over the Tymar on my 01' F-350 PSD. I plan on attaching the fender wall boot into the box along with the Zoodad but not sure how a Zoodad would tie into the system. Isn't the AIS fed by it's own dedicated air intake opening on the right side of the grill? If so, how would a Zoodad help since the filter is inside a box? Plus, looking through the grill where the hole should go, on my 01' it's painted metal, not fiberglass. I rather not have to saw through that unless I know what I'm doing. |
im going to try and explain it the best i can so bare with me...lol. the easiest way for me to explain it, is take a look at your existing air box/battery tray...if you look just to the left of your driver side battery there is a "snorkel" that goes towards your grille. the AIS has one of these snorkels too but its easier to see because it eliminates the whole battery box thing. if you follow where that snorkel ends up you will see it goes to a fiberglass header panel. i went onto google images and typed in "zoodad mod". the first picture on the top left shows right where you should make your cut. i hope i helped you and didnt confuse you.... |
